Surface Points
Like Tree17Likes
Old   April 19, 2016, 15:26
Supersonic is on a distinguished road
I did, but that only works for that specific case. I was hoping I could do it for one case, save it, and then copy and modify the case in Design Modeler. Thanks for the advice.
Supersonic is offline   Reply With Quote
Old   April 19, 2016, 16:02
Hi Chris,
Thank you for this post, it was very helpful! I have used this to create my 100 surface points. Now I have 3 quick questions.
1. When I do this it says "Warning : point creation failed" but when I "manage" my points, I can see them all there. Do you know why it is doing this?
2. Is there a way to check to make sure they are all in the correct place?
3. Is there a way to automatically (with code like before) group my points together into different groups?
Thank you very much for the help!
Old   April 26, 2017, 03:08
Default Writing iso-surface file
  #23
Ramnath
aeroramji@gmail.com is on a distinguished road
Hi everybody,
I am simulating heat transfer problem in a rectangular duct for which I need to create more than 200 iso-surfaces.
When I change the Reynolds number and run the simulation, I am supposed to create the same 200 iso-surfaces.
Is there any way to use a set iso-surfaces created in one fluent to another fluent file in Journal format using TUI command.
aeroramji@gmail.com is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
