June 1, 2010, 16:40 |
How to initialize a case file with udf?
sima
Rep Power: 16 |
Hi.
I want to initialize a case file which contains a udf. Two "define macros" have been written in this udf, but when I initialize in order to start iterations, the following error appeares: Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () What is wrong? Regards, S |
July 1, 2010, 04:43 |
can not initialize case with udf
#2 | |
same problem with you ,let's share our ideas,thank you ! |
August 3, 2010, 02:44 |
#3 | |
sima
Rep Power: 16 |
UDF with output text file | manu | Fluent UDF and Scheme Programming | 18 | December 12, 2018 23:46 |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 07:29 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 10:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
UDF (write a data file) problem | lichun Dong | FLUENT | 2 | July 29, 2005 12:39 |
