Extracting Surface Monitor Data
Old   October 28, 2009, 10:19
Default Extracting Surface Monitor Data
John Gallagher
johngsl is on a distinguished road
Hi all,
I am running several models so far in Fluent. I have two monitors in each model creating a graph each time step showing the concentration CO2. I need to extract the time step data to compare it to other models. Unfortunately, I ran the models to date without ticking the print and write boxes in the surface monitor window. Is there any way i can recover the data without having to run the models again?
John
johngsl is offline   Reply With Quote
Old   November 1, 2011, 05:45
chg
chg is on a distinguished road
I would love to know an answer to this problem too.
chg is offline   Reply With Quote
surface monitor data
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 14:43
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
