Case check - Velocity-Inlet not compatible with compressible flows
Old   September 15, 2009, 08:16
Question Case check - Velocity-Inlet not compatible with compressible flows
fluent-user's Avatar
fluent-user is on a distinguished road
Fluent case-check reports: Change inlet boundary conditions. Velocity-Inlet boundary conditions are not compatible with compressible flows.
Actually there's no compressible flow defined. Defined fluid is a mixture consisting of hydrogen and carbon-dioxyde, both with constant density and volume-weighted-mixing-law defined for the mixture.
Does anybody know the reason for this problem?
kind regards
fluent-user is offline   Reply With Quote
Old   September 15, 2009, 09:36
anonym
Laci is on a distinguished road
In the available materials in fluid panel air is still there (as default). Maybe there you set compressible density before.
Laci is offline   Reply With Quote
Old   September 15, 2009, 09:46
Thanks for your fast answer, but i think you didn't get the problem. Maybe my description was bad.
The problem does not concern the fluid or mixture, i don't understand the cited case-check message from fluent, because there doesn't exist any compressible flow in the domain.
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 06:35
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
Compressible flow with inlet velocity Ma%23601 klaus OpenFOAM Running, Solving & CFD 2 July 3, 2005 16:43
velocity more than INLET velocity neu FLUENT 3 May 13, 2003 05:56
length scales at inlet for internal flows Anne-Marie Giroux Main CFD Forum 3 July 5, 1999 22:28
