why the inlet velocity magnitude differrent from the value i initialize? |
August 27, 2012, 10:38 |
#21 |
Guiliguili
Rep Power: 16 |
I can't see the xyz coordinates of the second image from FLUENT. It's not clear because it's too small.
August 28, 2012, 02:56 |
coordinates in gambit&fluent
#22 |
kunar
Rep Power: 15 |
dear toure, please find the attached fluent image2
August 28, 2012, 07:12 |
#23 |
Guiliguili
Rep Power: 16 |
Nothing has changed except the view. You can change the view at Display -> View or use the mouse to turn it.
August 28, 2012, 09:44 |
#24 |
kunar
Rep Power: 15 |
Dear toure, thanks for kind response
1)In gambit & fluent both are default x is right, y is up & z is horizontal, according to my problem, For my actual geometry purpose, i select coordinates is x is towards right, y is horizontal & z is downwards if i choose default x is right, y is up & z is horizontal in gambit my wing looks up, but actual geometry my wing looks bottom thats why i choose coordinates is x is towards right, y is horizontal & z is downwards in gambit i didn't select default. 2) After i import in fluent, its take default coordinates in fluent, it will not change according to gambit coordinates, how i can change my coordinates in fluent according to my gambit coordinates? that's is my doubt. what i feel is In fluent may be some -/+ sign problem will occur in boundary condition or other condition like velocity inlet due to this coordinates. 3) If both gambit&fluent default coordinates means its okay. 4) if u didn't understand you take any 3D problem change coordinates(ie different view in gambit) and do your meshing in gambit, then see in fluent how the xyz coordinates changing.It will not give same coordinates in fluent as in gambit. please help me |
August 30, 2012, 19:55 |
#25 |
Guiliguili
Rep Power: 16 |
I am not familiar to Gambit but the change of view doesn't have any effects on the coordinates. If you have any point A of coordinates (xA, yA, zA) you flip it in Gambit or Fluent, it will still the same A(xA, yA, zA). You can check the dimensions of the domain in FLUENT (Mesh -> Scale).
August 31, 2012, 03:30 |
#26 |
kunar
Rep Power: 15 |
Dear toure,
thanks a lot for giving your kind response for my queries. |
April 20, 2015, 22:34 |
#27 |
sanjeet Limbu
Rep Power: 11 |
Dear sir
I am trying to compress the fluid inside the cylider as 2D axi-symetric partially premixed model I am not getting pressure rise... infact pressure initially very low may be not sufficient fuel mixture... Can u tell how to input the mass / or quantity for cell-zone type |
unsteady inlet velocity udf | jill | FLUENT | 8 | February 10, 2015 07:04 |
velocity inlet vs pressure inlet | cheong | FLUENT | 6 | April 9, 2011 04:07 |
pressure with velocity inlet boundary conditions | Ashraf Sharara | FLUENT | 1 | August 21, 2008 08:29 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 12:21 |
How to improve Velocity magnitude | ravi | FLUENT | 0 | June 23, 2003 14:17 |
