July 18, 2008, 14:24 |
Animation of vectors
How do we get vector animation? I tried it the as given in the guide for contours but it didn't work and also when superimposing vectors on top of contours. Any suggestions?
July 20, 2008, 10:22 |
Re: Animation of vectors
May I know what error you are getting
July 20, 2008, 11:48 |
No error. Its just that I can not see them moving. They are still.
July 21, 2008, 02:02 |
two possibilities:
1. you have to initialise the animation before the iteration- have you done that may i know number of frames that u given |
July 22, 2008, 10:46 |
I have not defined any key frames. I am following the procedure given in Tutorial guide > Modeling Unsteady Compressible Flow > Step 10: Saving and Postprocessing Time-Dependent Data Sets
Thanks for the help. |
July 22, 2008, 20:47 |
in solve->Animate->playback press "Write" and save the file in mpeg format.
Now open the mpeg file from the folder I hope you should get the animation, if not send let me have a look. If you dont mind can you send me the pexit.c file to me. |
Velocity vectors | SA | Main CFD Forum | 1 | March 8, 2007 02:04 |
udf and vectors | Short | FLUENT | 1 | February 9, 2006 01:43 |
Instantaneous and Mean Vectors looks same | anindya | FLUENT | 0 | June 14, 2005 01:42 |
Angle two vectors. | Guest | Main CFD Forum | 6 | May 20, 2004 05:06 |
Vectors and matrices in UDF | Ale | FLUENT | 0 | May 23, 2002 06:46 |
