Particle residence time!!
Old   June 12, 2008, 01:03
Default Particle residence time!!
Kandy
Hello there,
I want to calculate the age of air in a volume.
will, calculating the particle residence time give me a solution on this. if so can you please tell me how i can do it.
Please let me know.
Thanks Kind Regards Kandy
Old   June 12, 2008, 01:35
Default Re: Particle residence time!!
Allan Walsh
Try pathlines colored by particle residence time. I have used this to visually get an estimate of residence time without any text summary statistics.
Old   June 12, 2008, 05:55
novice
I think you have to define particle injections using Discrete Phase Model. Using DPM u can define particle injections from a surface(for ex: from inlet).
best regards
Old   June 12, 2008, 18:07
red lemon
you need not use DPM. You can use a user defined scalar that is seeded into the domain. Just solve your steady case then setup the UDS and solve a few iterations (say 5 or 10) for the UDS. Your support group can provide details of this UDS approach or I can if you cannot obtain.
Old   June 12, 2008, 21:17
kandy
Thanks Guys!!
We din't purchase support in the package.
Please type me in the details in your spare time. i will be highly obliged.
With Kind Regards
Kandy
Old   June 13, 2008, 05:18
novice
Hi Red lemon,
Can u please send me the procedure u worte. It will be interesting for me how to do this task using a udf.
Regards
Old   June 13, 2008, 05:31
Fluent_guy
dear sir,
yes, pls tell us the procedure for the Eulerian-Eulerian model. I mailed Fluent.Inc many times, but without any reply from them. They refer to Solution No. 619. However, this method is not suitable for RTD measurement of multiple dispersed phases. (if anyone requires the solution 619, i can paste the same here) red-lemon,we are all hoping for your reply.
thanks and regards.
Old   June 13, 2008, 09:32
red lemon
ok I will post use of uds for residence time. It is the same method employed in Airpak that uses Fluent but in this case it is done in the GUI in a simpler format and Fluent's method is a bit confusing. Bear with me as I recover details.
Old   June 17, 2008, 14:51
red lemon
OK here you go.
Convert this text to a *.c file then compile as usual and follow notes to hook in. Then solve for scalar only and post process.
/* Diffusivity for mean age of air
is solved using a user-defined scalar. This
calculation can be performed after the normal
problem has already been solved ... just turn off
all of the previous equations being solved for
and activate solution of the user-defined scalar-0
equation. Make sure to select
- mean_age_diff as the uds diffusivity in the materials panel
- mass flow rate as the uds flux function
- mean_age_source as the uds volumetric source term in
all fluid regions
Use a journal like this to do that in F63 :
def bc fluid fluid-1 n y 0 0 0 0 0 0 0 1 n y "mean_age_source" n y 0 0 0 0 0 0 n n n
def bc fluid fluid-2 n y 0 0 0 0 0 0 0 1 n y "mean_age_source" n y 0 0 0 0 0 0 n n n
def bc fluid fluid-3 n y 0 0 0 0 0 0 0 1 n y "mean_age_source" n y 0 0 0 0 0 0 n n n
etc
- set uds-0 scalar values = 0.0 at all inlets and outlets
mean age of air calculations do not require
any energy, radiation, or species transport
calculations to have been performed
#include "udf.h"
#include "prop.h"
DEFINE_DIFFUSIVITY(mean_age_diff, c, t, i)
return C_R(c,t)*2.88e-05+C_MU_EFF(c,t)/0.7;
DEFINE_SOURCE(mean_age_source, c, t, dS, eqn)
dS[eqn]=0;
return C_R(c,t);
Old   June 25, 2008, 12:03
learning_never_ends
Hi red lemon,
This is for a single-phase flow..but what should we do if we have multi-phase flow and need to claculate the residence time of the dispersed phases only ?
Thank you.
Old   June 25, 2008, 22:13
  #11
kandy
Hi red Lemon,
Thank you very much.
I was on holidays. will try this.
Thank you one again.
Regards
Kandy
Old   October 20, 2011, 07:39
Default Hi to every one...I want know How to post process the Mean age of air in fluent.. Ple
  #12
Hanumanth
p08tm007 is on a distinguished road
Hi to every one...I want know How to post process the Mean age of air in fluent.. Please any one can help regarding this...Thanks in advance ....
Originally Posted by red lemon
;151570
OK here you go.
all fluid regions
etc
#include "udf.h"
#include "prop.h"
dS[eqn]=0;
return C_R(c,t);
p08tm007 is offline   Reply With Quote
Old   January 26, 2016, 05:51
Smile
  #13
James
Tensian is on a distinguished road
Hi everyone,
In your diffusivity formula:
Which values should I choose for a water system?
Also, I am finding several difference on maximum residence time when I increase mesh size. I guess this is just an issue of the faces that the UDF is taken into account, and if element size tends to zero, then this maximum residence time will converge for a constant value...Am I right?
Thanks in advance!And special thanks for sharing this useful tool!
Tensian is offline   Reply With Quote
Old   February 7, 2019, 05:01
Smile meanagofair does not appear in varialbles inside results
  #14
jason
jas1903 is on a distinguished road
How do i post process mean age of air?
Thanks
jas1903 is offline   Reply With Quote
partickle-tracks and udf, particle-residence-time Alex FLUENT 0 August 15, 2006 04:46
Particle residence time Philip FLUENT 0 June 16, 2006 04:30
how to get the particle residence time in UDF? welch FLUENT 0 November 17, 2005 20:32
Particle Residence Time Ethan Siemens 0 July 29, 2002 15:45
Particle tracks and residence time Bo Jensen Siemens 1 January 10, 2002 05:19
