boundary pressure value at the face open to atmosp
Old   April 21, 2008, 10:50
Default boundary pressure value at the face open to atmosp
Gaurav Mehra
HI all!
I am little confused here if you people can help me. I have a cylinder which is partially submerged in water. its opened at both ends and one end is exposed to atmosphere(out of water) and one end is inside the water.( 80 cm vertical cylinder with 50 cm of it submerged in water.) I have defined at the bottom face of this cylinder as pressure inlet which I shall be giving a pressure UDF from this face and the upper face is defined as pressure outlet. Now to set values on these two faces, what gauge pressure should I set at the upper face and what value of gauge pressure at the bottom end. Kindly someone suggest. Should I put 0 gauge pressure at the top face or 101325 pascal??
Pressure inlet boundary conditions for open channel flows jack2000 OpenFOAM Running, Solving & CFD 5 December 6, 2018 12:00
FACE MACROS FOR PRESSURE Sandilya Garimella FLUENT 4 May 4, 2012 07:12
Average pressure on a face. Mario Tremblay CFX 2 February 19, 2009 14:08
how to color the face by pressure or volecity? superfool FLUENT 0 January 2, 2007 20:51
Open boundary for pressure in twophase flows Tony Main CFD Forum 1 March 2, 2002 13:40
