DYNAMIC MESHING
Old   April 11, 2008, 06:35
Default DYNAMIC MESHING
Anna
Hi, I am working on a dynamic meshing problem using version 6 of fluent. Im focusing on using the spring based smoothing method and remeshing options. I was wondering if anyone knew of any good papers or reference material with examples of this kind of work. Obviously I have already got the fluent notes and tutorials from the help manual, so anything additional to this.
Old   April 11, 2008, 11:27
Default Re: DYNAMIC MESHING
Teo Fumagalli
Hi Anna, please be more specific. What's your problem? What do you want to do?
Old   April 15, 2008, 08:18
Anna
im simulating a 2D oar moving from catch to finish as in a rowing stroke. So it moves in an arc relative to the hull of a boat.
All i want to know is if there are any good papers out there detailing dynamic meshing through the smoothing and remeshing options in fluent.
Old   April 15, 2008, 08:30
Teo Fumagalli
Try this:
http://www.fluent.com/software/unive...strategies.pdf
it gives you an idea of the possible remeshing strategy with relative options. Hope it will be helpful.
Old   April 15, 2008, 08:36
Anna
Thanks, but i have already got that helpsheet, im hoping to find a journal paper or something with some detail on the use of dynamic meshing with an application. To give you an idea of what im looking for i have come across a paper called Two-dimensional simulation of unsteady marine propulsor blade flow using dynamic meshing techniques by Rhee S.H. it is free to view via sciencedirect of google scholar, something along the same lines as this...
Old   April 15, 2008, 09:04
Teo Fumagalli
Very nice paper. Sorry I can't help you then.
dynamic meshing? tom FLUENT 0 March 9, 2009 16:49
dynamic meshing Anna FLUENT 2 April 4, 2008 07:48
Dynamic re-meshing Jack FLUENT 2 April 14, 2006 06:52
Dynamic Meshing Philip FLUENT 0 February 2, 2006 17:06
Dynamic Meshing Max FLUENT 1 September 20, 2003 15:13
