April 10, 2008, 07:25 |
Import geometry in GAMBIT
I'm dealing with CAD geometry realized by Solidworks Is it importable in GAMBIT? Which is the right extension file?
Thanks |
April 10, 2008, 07:56 |
Re: Import geometry in GAMBIT
you can try with STEP file (I currently use this way)
April 10, 2008, 13:42 |
you can try sat file. i actually dont know if solid wokrs can export this kind of geometry, but fluent can read it.
April 11, 2008, 04:26 |
Read in the parasolid file directly (*.x_t) and use the direct read option (File>Import>CAD>Parasolid direct read) or use translation to convert from parasolid format to native GAMBIT ACIS format (File>Import>Parasolid). The former is less likely to corrupt data but will come in as virtual hence reduces geometry operations (entities will be c_*), though you might be able to convert. Also you can use the Gambit SOlidWorks CAD connection tool at v1.2.4 (for 2006/7/8) which is free and can be obtained from www.fluentusers.com which will help with transfer.
April 21, 2008, 06:42 |
you can save as the solidworks file as .igs, .step, .parasoid and then import it into gambit. Thanks rupal |
Import 2D Geometry to Gambit | Nathan | ANSYS Meshing & Geometry | 3 | March 27, 2017 11:26 |
import geometry in GAMBIT | cristiano | FLUENT | 27 | November 6, 2014 18:43 |
GAMBIT, CAD import, clean up geometry problem | Nuray Kayakol | FLUENT | 1 | December 30, 2007 12:43 |
iges geometry file gambit import | giacomo | FLUENT | 0 | May 14, 2007 13:32 |
Multiple import of Geometry in GAMBIT(Catcon Simu) | Amod kumar | FLUENT | 0 | July 22, 2006 00:55 |
