defining periodic boundary on an annular face
Old   December 18, 2007, 07:57
Default defining periodic boundary on an annular face
jaysree
I am doing 2D simulation on the annular reegion two rotating cylinder using axisymmetric swirl flow. For this I need periodic boundary on the annular face. But I donot know how to define the periodic boundraies.Kindly help me. Thnak you verymuch.
Old   December 19, 2007, 00:03
Default Re: defining periodic boundary on an annular face
Vijay
Hi Jaysree,
For a periodic boundary without any pressure drop, there is only one input you need to consider: whether the geometry is rotationally or translationally periodic.
With Regards,
Vijay
Old   December 19, 2007, 06:29
jaysree
That is correct. But how to define the boundary in gambit. though I know partially the procedure to make the boundary periodic in gambit, but donot have any idea for putting which boundary to be periodic. For example if I have a rotating face connected by 4 edges, which edge will be periodic. Kindly help me. Thank you very much for ur help
Old   December 19, 2007, 06:49
Vijay
Dear Friend,
To apply a "periodic" boundary condition for use with a FLUENT solver, you must first create a mesh hard link between the pair of edges (2-D) or faces (3-D) to which the boundary condition is to apply. In addition, you must assign a PERIODIC boundary type to both edges (or faces) in the pair, and both edges (or faces) must constitute members of a single entity set.
With Regards, Vijay
Old   December 20, 2007, 03:54
jaysree
Can I use axisymmetric swirl model with periodic boundaries.
Old   December 20, 2007, 04:30
Vijay
Dear Friend,
Please wait for 2 or 3 days i will send u the help file, because now i am out of station......
Regards, Vijay
Old   December 20, 2007, 04:46
jaysree
Thank you verymuch.
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
defining flux across face for interior boundary Sandilya Garimella FLUENT 2 October 10, 2009 01:05
[Commercial meshers] Converting meshes that includes interfaces ham OpenFOAM Meshing & Mesh Conversion 29 January 8, 2007 09:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
