December 12, 2007, 16:40 |
Lobe pump + Turbo in Gambit
Hello, I am trying to prepare a model of a lobe pump with Gambit. I shall later run the simulation in Fluent. My questions is: Do we need the TURBO function of Gambit in order to model the Lobe pump or it can be done withoout the turbo function. Thank you.
December 13, 2007, 04:34 |
Re: Lobe pump + Turbo in Gambit
G/Turbo is just a advanced modelling tool,you can model pump in any software
it will take lot of time using TURBO is an easy thing once if u understand how to prepare the model with turbo u need very less no of curves with turbo one more addin is there for pupm type proublem "GT Pump" with this u can able solve proublem al most with Gambit only this addin will come like this --->tool-->addins there u can find GTPump and add the addin and solve and try it about this this see the manual ok |
[GAMBIT] problems with gambit tools turbo | qxtxdy | ANSYS Meshing & Geometry | 0 | October 15, 2010 23:33 |
gambit turbo file format | ventoneac_diana | Main CFD Forum | 0 | April 29, 2010 13:02 |
gambit turbo file | juancajara | FLUENT | 1 | February 7, 2010 13:33 |
Gambit turbo problem. | sujan.dasmahapatra | FLUENT | 0 | December 20, 2009 06:21 |
export from pro-e as turbo file gambit | cosimo | Main CFD Forum | 0 | August 18, 2006 13:40 |
