August 6, 2014, 04:02 |
#21 | |
Amin
Rep Power: 15 |
If your angular velcity is great it can make difficult to convergence for solver! In this conditon, starting with a low velocity could help you for convergence! |
July 22, 2015, 03:59 |
#22 |
Temidayo
Rep Power: 11 |
Hi guys, I first of all appreciate everyone here, I am new in here and new to CFD. i am working on inpipe turbine. I used 1.4 m/s inlet and unknown outlet in autodesk cfd, with 3Xdia upstream and down stream. I initially ramp up the rotatin region to 2400rpm as an ideal RPM, then later change the rotating region to free spinning then further time step till another steady state RPM was gottn. but i dicover that my unknown volume flow rate is higher than inlet after the simulation. also, when i plot the inlet point and outlet point i discover that my result inlet velocity is higher than the what i initially specified. pls guys i need ur help
July 27, 2015, 02:38 |
#23 |
hashim
hi, which approach are you using means MRF or any other
second, what does unknown outlet means, are you using pressure outlet and also is your mesh is fine enough? kindly clear these things i will try to help you out |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 06:58 |
Pressure Boundary Conditions | Dave | FLUENT | 2 | June 8, 2009 18:05 |
pressure boundary conditions | A.Shaija | Main CFD Forum | 0 | June 30, 2006 01:51 |
How to Define Pressure Boundary Conditions? | Sheenu | Main CFD Forum | 4 | May 12, 2000 13:52 |
