Seeding the Flow - Tracer gases?
Old   August 20, 2007, 21:43
Default Seeding the Flow - Tracer gases?
Carlos
Does anybody know how to seed airflow in fluent models? I am looking at steady-state airflow inside a livestock trailer. I want to look at ventilation rates within the trailer but volume flow rates are not adequate.
They do not allow for air exchanges. So I want to seed the airflow and look at how long it takes for these 'seeds' to exit the trailer. Obviously my model is steady state but if I could do some kind of analysis in fluent maybe I can calculate a residence time.
Since the air velocity in the trailer is low in places, it will take more time for tracer gases/seeds to exit the trailer. Does anybody have any ideas?
Also, I am modeling humidity in fluent using the species transport model. Having set up sensible boundary conditions I get relative humidities of 1000's of % when I post process - this should be no more than 100%! Any ideas on what is wrong?
Best regards,
Carlos.
Old   August 21, 2007, 03:43
Default Re: Seeding the Flow - Tracer gases?
Razvan
Hi Carlos,
You have an already implemented option to calculate the residence time: the DPM model. Just create an injection of inert massless particles from the inlet, run the simulation to convergence (in steady solver) and calculate particle residence time, option available in DPM panel, if I remember correctly.
About humidity levels, I have no answer for you, I never encountered this problem.
All the best,
Razvan
Old   August 23, 2007, 12:15
Carlos
Hi Razvan,
You are an extremely useful contact on here and your input is valued! I will try your suggestion of seeding the flow, I hoped there would be such an option in Fluent.
All the best,
Carlos.
Fully Developed Flow in Star-cd SMM STAR-CD 0 September 5, 2011 23:08
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 06:16
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 08:40
Tracer Analysis in CFX Graeme CFX 11 October 25, 2005 11:02
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 3, 1999 00:18
