problem with axisymmetric flow-how to monitor pts
Old   July 13, 2007, 06:36
Default problem with axisymmetric flow-how to monitor pts
James
I have a 2d model that is axisymmetric. I want to monitor the pressure at a point.
I tried first by defining surface monitor and under report type, i selected area weighted average and then under surface, i created a line at the point where i want to monitor the pressure. Is this procedure right? or do i have to monitor the pressure instead at a point? When I run a 3d simulation, i monitor a plane by the using the point & normal function under surface for creating the plane....i am wondering what should be done in the case of a 2d flow.
The main problem i have is this. After recording the time series data in the line, when i plot it, i am seeing something like the data is being reflected because of the axisymmetry. Any idea why i am having this behavior and how can i correct it.
If you need further explanation, i can send you the plot by email attachment if you send me your email address.
Looking forward to a quick response.
James
Old   July 13, 2007, 10:04
Default Re: problem with axisymmetric flow-how to monitor
Joe
Why dont you just set up a point monitor?
Old   July 13, 2007, 10:55
James
I suspect i will get something similar. Why? I created a point and when i display the point, i saw two displayed........so i might get for each point two values recorded which will lead to to a similar problem.
I there a way i can prevent the symmetric point from being into account? or how do i deactivate the symmetric point?
James
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 09:40
Problem on boundry of two phase flow youngan CFX 0 June 30, 2003 03:32
Poiseuille flow problem Rosie FLUENT 1 December 6, 2002 17:52
