GAMBIT 3D Boundary Layer ERROR
Old   May 14, 2007, 23:19
Default GAMBIT 3D Boundary Layer ERROR
sucho
Hi, Forum..... PLease help me... What is causing following error??
Error: Currently, 3D boundary layers are limited to flat face groups with END conditions around the boundary. The problems occur in v_volume.3 along v_edge.187 edge.160. v_edge.194
Old   May 22, 2007, 09:57
Default Re: GAMBIT 3D Boundary Layer ERROR
Neil
Could be because the enities are virtual, try changing them to real volumes and edges. Also try just using edge BL meshes to form what would be the face BL mesh, sounds stupid but its worked for me in the past.
Neil
Old   May 23, 2007, 07:54
Default Re: GAMBIT 3D Boundary Layer ERROR CODE 1
Stefano
Hi Forum,
I'm trying to create a boundary layer in an unstructured mesh volume (triangular). Gambit returns me the "ERROR CODE 1"....i don't know what to do. Can you help me?
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 06:18
