Rosin Rammler Distribution
Old   March 7, 2007, 06:26
Default Rosin Rammler Distribution
AndiG
I want to inject particles in my continous phase. I`m using the surface injection, the particle-sizes should apply to a certain distribution. I calculated the spread factor of my distribution for the rosin rammler method according to the manual. But when I look at the results the distribution shows a uniform shape. The diameter have a linear size distribution between the minimum and maximum value i set, but they are not disributed in the way I want (rosin rammler).
In my opinion the diameters released from each surface cell should be disributed with the spread factor I set. But they are sized linear between the min and max value I set.
So whats wrong with it?
Thank you for your efforts
Andi
Old   March 7, 2007, 11:56
Default Re: Rosin Rammler Distribution
Seeker Phil
Hi Andi, Have you looked at the mass fractions of the different droplet sizes as well? The Rosin-Rammler distribution is a combination of droplet diamter and mass fraction above that diameter. So you might see the diamter distribution as linear, but the fractions of different sized droplets might be more accurate. - Phil
TAB (Taylor Analogy Breakup) Model Zi-Wei Chiou Main CFD Forum 15 December 19, 2023 10:27
Rosin Rammler Distribution mystix OpenFOAM Running, Solving & CFD 10 February 11, 2021 06:23
rossin rammler distribution in DPM hendar_k FLUENT 0 May 23, 2011 04:18
maintaining a logarithmic velocity distribution Morten Andersen CFX 1 January 8, 2007 12:37
DPM-Rosin Rammler distribution -CV probleme olivier FLUENT 2 August 8, 2001 13:13
