Remove species through a Wall
Old   October 19, 2006, 04:33
Default Remove species through a Wall
PK
I am trying to simulate the problem of a capture of a species in a 2 species flow (for exemple S1 is the main specie and S2 is the second one). It is a 2D problem and the flow is the one around a cylinder defined as a wall (for example). This cylinder is the source of the capture of the S2. have several questions (even after going through some related questions in this Forum). -I guess that I have to use the user DEFINE_SOURCE macro and write my own UDF -WHen I am removing S2, shal also remove the coresponding momentum (opposite problem when adding a specie in a cell) : if so how should it be done excatly ?. -What about if this capture concerns not only the neighboring cells but also a depth of cells around this cylinder ; how to access to those cells ?. Thanks for your help
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 07:23
Species through a wall. Andrew Garrard FLUENT 25 October 12, 2005 06:10
Wall functions? Pr Main CFD Forum 7 April 8, 2004 07:15
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 05:29
