Hypersonic flow capabilities
Old   October 5, 2006, 21:52
Default Hypersonic flow capabilities
Gaurav
Can FLUENT handle hypersonic flows, i.e. say a velocity of Mach 20 - 30, which may be experienced by space shuttles during reentry?
If not, is there any other software in the market which can, or is specifically suited to do so?
Thank you.
Old   October 5, 2006, 22:03
Default Re: Hypersonic flow capabilities
Ahmed
If you write the proper UDF functions to handle the effects of dissociation on fluid properties, the answer is Yes
Old   October 6, 2006, 10:10
Chandra Murthy
Fluent's density based solver(Coupled sover) does not have any limitation on Mach number. Using UDF for air chemistry to account for dissociation of air, you can get better results.
Old   June 4, 2014, 15:02
Default UDF to Model Finite Rate Chemistry
Mike
dreamchaser is on a distinguished road
I am simulating hypersonic flow over a sphere.
I would like to use Fluent's Finite Rate Chemistry Model.
I have a reaction file which I used on CFD++ software. However, I realized that I need to re-format this UDF to use in Fluent. Does anyone have advice on the structure of this UDF?
If anyone has an example UDF with the correct format for the reactions, I would be greatful!
Thanks
dreamchaser is offline   Reply With Quote
Hypersonic flow setup screech1987 STAR-CCM+ 6 April 27, 2011 16:00
Hypersonic flow rhoCentralFoam ishaninair OpenFOAM Running, Solving & CFD 0 April 7, 2011 05:38
Hypersonic flow Subramani FLUENT 8 May 7, 2007 21:02
Multigrid for hypersonic flow Jeff Main CFD Forum 0 October 20, 2002 21:50
Hypersonic flow applied to blunt nosed (ie. 2d bodies) manishkumar Main CFD Forum 1 January 10, 2000 23:36
