September 25, 2006, 14:26 |
low rey Naca 0012
how good is fluent in predicting the drag and lift at very low reynolds number...for example at re of approximately 5000. When I run the lift is quite good but the drag is very small unlike that shown in an exp paper which I found...has anyone done simulations at this very low re....if so did you get good results
September 25, 2006, 17:10 |
Re: low rey Naca 0012
5000? that's laminar flow.
If you wanna get simulate transition process you have to use v2f turbulence model. But, I'm pretty sure Re=5000 it's fully laminar flow. |
September 25, 2006, 18:04 |
ya....I used only laminar....the values are way of the exp values
September 25, 2006, 18:44 |
Hi Ravi, I´m dealing with the NACA 0012 too, but with a reynolds of about 360k. Comparing with differents turb models I got relatively goods numbers on the Cl´s, but the Cd´s are 10 times over the real values. A question, can you email me the paper you have with the values? I´m using a soft called Snack to get the numbers for comparing with my CFD results. You can mail me at agriotti@gmail.com How do you set up the references values? I want to compare with mine.
Thanks! |
September 26, 2006, 13:07 |
ofcourse you are going to get those Cd values. at Re 360k, depends on the angle of attack, you have transition at 40% chord more or less. And you are modelate it fully turbulent. YOU HAVE TO USE V2F TURBULENCE MODEL, this model is able to modelate the transition process.
September 26, 2006, 16:34 |
Great, thanks for the tip Pablo!
How to import NACA 0012 Profile in Gridgen | maplepink | Main CFD Forum | 17 | May 7, 2013 14:01 |
Problems with flat plate and NACA 0012 Lift/Force | Harly | FLUENT | 0 | June 18, 2007 11:02 |
NACA 0012 simulation results | Luis | FLUENT | 3 | February 15, 2006 12:42 |
NACA 0012 data for Low Re | Khurram | Main CFD Forum | 5 | May 10, 2005 12:05 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
