Dynamic re-meshing
Old   April 11, 2006, 21:52
Default Dynamic re-meshing
Jack
I'm trying to simulate flow between a stator and a rotor inside a pipe. More like a screw conveyor. Can Fluent handle such a situation by dynamically re-meshing the geometry at every time step?
Old   April 14, 2006, 06:52
Default Re: Dynamic re-meshing
Freeman
Yes, of course. In Adapt -> Gradient menu there is the option Dynamic. When it is switched on, you can tune an "interval dial" where this interval is each time step (if you are preforming unsteady simualtions) or an iteration (if you are making steady state sims.)
I would not recommend you an interval=1 (each time step) unless you have a small 2D grid or you have a "NASA-like" computer.
Freeman
Good luck!
Freeman
dynamic meshing pronik_zoro ANSYS Meshing & Geometry 0 March 12, 2011 12:01
Dynamic meshing Manoj Kumar FLUENT 3 June 27, 2010 20:26
[GAMBIT] Dynamic Meshing of a combustion chamber donarundas ANSYS Meshing & Geometry 1 December 2, 2009 08:13
Issues with dynamic meshing sridhu88 FLUENT 1 June 11, 2009 17:46
dynamic meshing option arehman Main CFD Forum 4 June 27, 2004 03:55
