April 4, 2006, 12:11 |
Fluent export function
I need to find a way to export the pressure of my finished calculation. The problem is that I need to export the pressure on a equidistant(uniform) mesh but I am using an adapted mesh. Does anybody know how to to this export easily? I already thought of using the export on a rake function Thanks Ben |
April 4, 2006, 13:13 |
Re: Fluent export function
U can do this using extrapolation or interplation function in Fluent
April 4, 2006, 14:57 |
How can I do that in detail? Can I do it by using the graphic interface or do I need to use the batch mode?
April 5, 2006, 04:56 |
See u create another grid where u want ur value to be now from the orginal grid u can do the interpolation to a newer grid.
Read the manual! This is how I also know thi information. You can do this usin graphical user interface |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Wall function formulation in CFX and Fluent | gravis | ANSYS | 0 | May 4, 2010 12:03 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 07:59 |
Export from Fluent | Sameer Jaju | FLUENT | 1 | April 16, 2008 02:29 |
