How does a Fluent LICENCE works?
Old   March 29, 2006, 13:15
Default How does a Fluent LICENCE works?
Freeman
Hi all!
I am a Fluent user which uses it at the university with academic purposes. The fact is that one day I had to work with the PC of the administrator of the licecnce for the university and the coincidence was that he had logged in to fluentusers.com and left the window opened.
While I was in this PC I kept an eye in this site and there's a section called Download center of something like this. It seems the administrator can download all Fluent products with one licence, because it appeared a list with all fluent programs to download. I stopped there because I didn't want to cause problems but I have a question: how a licence works? I mean, if I buy a licence, I really buy a "KEY" and then I am able to download Fluent, Gambit, TGrid or whatever?
It's just curiosity xD. Thanks!
Old   March 29, 2006, 13:45
Default Re: How does a Fluent LICENCE works?
Jan
If you have a username and password to fluentusers then you can download all the software even without a license. But you need a license key to run each software whcig you can purchase from fluent
Old   March 29, 2006, 14:52
Freeman
Thanks Jan: I imagined something like this...
When you say:
"But you need a license key to run each software whcig you can purchase from fluent"
So with the current licence which in our university are using Fluent and Gambit we cannot download and use any other, no? One licence for one software I mean...
By the way, somebody knows the licence price for TGrid? It should be not as expensive as Gambit is I imagine: something around 1500$ perhaps...?
Thanks for your participation
Old   March 31, 2006, 03:06
CFD-Jnr
TGrid comes with the standard package i.e. your current license already has TGrid. If you need an extra TGrid license - you probably need to discuss this with your distributor but chances are that it would be cheaper since you have a student license
Old   April 14, 2006, 06:58
Freeman
WHAT? Are you referring that the standard Fluent licence also let me use TGrid?
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Fluent licence costs novice FLUENT 0 August 9, 2010 08:46
Fluent connection with simulink by TCP/IP Tanktruck Fluent UDF and Scheme Programming 1 June 28, 2009 13:56
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
