January 27, 2006, 03:42 |
How solver works?
How solver works?i.e. after solver starts how it calculates values of pressure and velocity?does it initially take all values zero?This is as i have observed when solver is running?
January 27, 2006, 06:50 |
Re: How solver works?
This is not a simple question...The solver starts with the values u have utilized to initialize the case. Elsewhere I think it takes 0 or default values. Pressure and velocity are coipled in the momentum equation, so the solver needs a 2nd equation that is a mathematical algorithm like the SIMPLE or PISO.
January 27, 2006, 14:35 |
The solver takes the initial P and V values as zero unless you specify you IC/BCs.
smoothSolver diverges - solution in using PBiCG solver? | makaveli_lcf | OpenFOAM Running, Solving & CFD | 3 | September 11, 2013 13:44 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 15:08 |
How solver works? | John | Fidelity CFD | 1 | February 24, 2006 10:23 |
How solver works? | John | Phoenics | 1 | January 27, 2006 13:25 |
