January 7, 2006, 11:10 |
Simple question about pressure outlet.
Hi, all
I'm used to run CFX and new to Fluent. I'm running a test case to simulate a ball moving in free stream :<font color=blue> A ball(dia=1m) inside a brick (20m x 20m x20m), with --one face(Xmin) velcity-inlet speed=1 m/s --opposite face(Xmax) pressure-outlet then I don't know what the other faces BC should be ? (I've used pressure-outlet/Outlet Vent, but it will always show that reversed flow on these 4 sides and the residule converged curve is not good)</font> Thanks in advance. K. |
January 7, 2006, 11:56 |
Re: Simple question about pressure outlet.
what is ur viscous model,ur problem seems to be a transition case, reversed flow is not an error.
January 7, 2006, 20:50 |
Thanks for response! What I'm really cared about is the reversed flow warning. Is there a boundary type suitable for openings which allow both IN & OUT in Fluent ?
January 8, 2006, 06:28 |
"Is there a boundary type suitable for openings which allow both IN & OUT in Fluent ?"
What exactly u want, when u r not sure about your outlet condition, use outflow boundary type in fluent |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 03:10 |
Simple Outlet Question | m.nichols19 | OpenFOAM | 3 | June 25, 2010 02:44 |
pressure inlet & outlet. help ASAP Plz | engahmed | Main CFD Forum | 0 | June 13, 2010 16:34 |
Collocated SIMPLE and outlet pressure | yhoarau | Main CFD Forum | 1 | April 16, 2009 10:16 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
