A doubt in linking the UDF to Fluent6.2 - SunOS
Old   November 22, 2005, 00:55
Default A doubt in linking the UDF to Fluent6.2 - SunOS
Kulasekharan
Iam running fluent in Sun OS Server in my university. when compiling a UDF (which ran successfully in Windows based fluent) iam facing a problem. Fluent tells syntax error in the first line itself.
iam using interpreted mode in reading the UDF.
i need help regarding whether any syntax has to be changed for making the UDF run compatibly in Sun OS 5.9.
Thanks in advance Kulasekharan N
Old   November 22, 2005, 16:32
Default Please post the error message *NM*
Zhang
flapping wing udf a serious doubt doctsh Fluent UDF and Scheme Programming 0 February 17, 2011 13:05
Please, Help with linking UDF precompiled outside fluent to fluent!!! gracerlima Fluent UDF and Scheme Programming 1 May 4, 2010 08:19
OpenFOAM with Cygwin kitchener OpenFOAM Installation 6 April 25, 2006 00:09
UDF Doubt Kulasekharan FLUENT 0 November 10, 2005 06:26
DEFINE_SOURCE UDF doubt ramesh FLUENT 1 May 29, 2004 08:13
