November 7, 2005, 12:17 |
Pressure drop
Hi I am simulating the flow(2D) in a fin and tube heat exchanger. (The geometry consists of a long rectangular tube with three rows of cyllinders placed perpendicular to the flow) I want to calculate the pressure drop between two surfaces. Can someone tell me , how Fluent calculates the pressures. I have gone through the User's guide and i found that fluent applies some corrections in calculating the pressures.(Ptot.=Pop.+Pgauge) I am using incompressible flows. So can anyone tell me how Fluent calculates the pressures.
thank u |
November 10, 2005, 02:22 |
Re: Pressure drop
Madhu,
In Fluent, static pressure is your local pressure and operating pressure you have to specify in the fluent panel. Don't get confused with static head,static pressure those are completely two different parameters in fluent.Hope it clears you. |
November 10, 2005, 04:05 |
Re: Pressure drop
Hi
I would like to know how the pressure is calculated in FLUENT...i mena which formulas FLUEN uses to do this thanks in advance |
November 12, 2005, 12:58 |
Re: Pressure drop
Fluent offers different pressure-Velocity coupling techniques like SIMPLE,SIMPLEC,PISO to calculate local pressure (Static Pressure).
pressure drop in the pipe | mike.mm | FLUENT | 6 | February 7, 2011 11:31 |
Pipe Flow - Pressure Drop | Daniel L | FLOW-3D | 2 | December 10, 2010 05:23 |
Total and static pressure drop | Janakiram | Siemens | 1 | February 8, 2009 02:32 |
Pressure Drop at entrance of a rotor-stator. | Resnick | Main CFD Forum | 0 | November 20, 2007 15:50 |
Periodic boundaries and pressure drop | MatejK | CFX | 2 | July 12, 2005 05:47 |
