can melt pool flow and plasma flow be simulated ?
Old   September 16, 2005, 09:38
Default can melt pool flow and plasma flow be simulated ?
wanghong
hi,everyone.when high power density laser beams act on a metal surface,local metal become liquid,almost at same time, part liquid can be evaporated to metal gas.immediately,the gas recoil pressure make liquid surface sunken,laser beams can be absorbed more,a keyhole full of plasma with about18000K in the metal is formed.i want simulate the keyhole formation process. i know VOF model is better in order to track liquid free surface,but can the plasma flow in the keyhole and melt pool flow be simulated at the same time?pls help! thanks!
Old   September 22, 2005, 21:29
Default Re: can melt pool flow and plasma flow be simulate
lana
I just start to adopt the VOF model for similar problems and I am experiencing big problems of convergence due to the big differences in properties between the phases.
Old   November 16, 2011, 19:21
navid
ndabir is on a distinguished road
Hi
Have you simulated your problem? I need some help on plasma propagation modeling induced by laser beam. I don't know if I can simulate it using the basic features of fluent. I don't want to use UDF at the beginning.
ndabir is offline   Reply With Quote
How to make simulation of body force in plasma actuator induce flow? mukut Phoenics 25 April 7, 2011 23:35
how to set electric permittivity in plasma actuator induce flow simulation. mukut Phoenics 3 November 1, 2010 22:50
Plasma Flow Modelling using Source term and cell's data Constantine Fluent UDF and Scheme Programming 2 May 19, 2010 22:06
Simulation of flow induced by plasma actuator mukut Phoenics 0 April 21, 2010 08:32
Reference for Plasma Flow Adam Wu Main CFD Forum 0 January 5, 2004 05:10
