Backward Step:DPM
Old   August 22, 2005, 23:25
Default Backward Step:DPM
mjkukbm
Hi All
I am trying to simulate multiphase using the discrete phase model over a backward facing step.The problem I am haveing is that the injection of particles don't seem to spread at all and continue in a straight line and don't enter the recirculation zone behind the step.
Is this a problem with the v-velocity component of the injection? This is unknown to me at the start of the simulation but I have set to 0.01 m/s (instead of default of zero)in the injection panel, however this produces a value 10 times to big in the flow field when compared with literature (0.1m/s).
Can anyone advise me on this matter?
Thanks
Old   August 26, 2005, 12:07
Default Re: Backward Step:DPM
David
Hi
did you get a positive response to this?
I do not know the answer but I would be interested to know.
David
Old   August 29, 2005, 06:16
mjkukbm
Hi
No I still haven't had any luck in succesfully replicating the flow of the particles around the step. I gave it even more v velocity at the injection to effectively exaggerate the sideways movement of the particles but they still carry on in a straight line.
I am beginning to think there maybe something up with Fluents discrete phase model with regards to this specific scenario or I am overlooking something very obvious.
Has any one else previously modelled a backward step using DPM? I would appreciate any advice.
Thanks
Euler, Backward time schemes idrama OpenFOAM Running, Solving & CFD 4 December 17, 2015 10:16
backward and Backward differencing formular (BDF) idrama OpenFOAM 1 October 27, 2010 20:32
Abort->Changing from Euler to Backward -> Running idrama OpenFOAM 3 March 4, 2010 06:07
Using both backward timeScheme/Crank Nicholson for LES And OpenFOAM 0 December 2, 2009 05:17
backward reaction alexandra FLUENT 0 September 5, 2001 16:23
