limiter
Old   August 3, 2005, 11:51
Default limiter
O.
Does Fluent have the possibility to solve supersonic flow with a higher than 1st order accurate method (e.g. limiters like MinMod, van Albada, ...).
Thanks, O.
Old   August 4, 2005, 00:00
Default Re: limiter
Swarup
I did not find any. Check with support team for any add-on/way out if available.
Swarup
Old   March 19, 2013, 11:53
Murdy Baskan
murdock88 is on a distinguished road
Limit minimum temperature, this improve supersonic flow convergence. I generally limit minimum temperature to 100. But if your mach number around 5 use must decrease minimum temperature to 50.
murdock88 is offline   Reply With Quote
Ultimate Flux Limiter gentela Main CFD Forum 1 August 2, 2016 21:55
acces limiter for instance generated by vanLeer scheme stevenvanharen OpenFOAM 0 August 31, 2011 11:13
slope limiter and flux limiter ?? Ameya J Main CFD Forum 1 June 13, 2011 13:05
Definition of limiter function for central dirrerencing scheme sebastian_vogl OpenFOAM Running, Solving & CFD 0 January 5, 2009 12:08
Moment limiter in DG method. jinwon park Main CFD Forum 0 May 15, 2008 13:18
