July 6, 2005, 20:33 |
FLUENT Parallel / sliding mesh
My simulation is a stirred tank, with sliding meshes. The setup is working fine. I am facing a problem when I save my case and data file in the parallel version of FLUENT 6.2 for windows. When I read back the files into the solver and asks for more iterations, it just stops, draining 100% of the processor, and do nothing. It is a bug in FLUENT or I have to do something else? Thanks for any help galeazzo |
July 10, 2005, 12:19 |
Re: FLUENT Parallel / sliding mesh
hi Galeazzo,
I want to know how u modeling the stirred tank. 1)Complete 360 geometry or 180 geometry. 2)How u modeling the interfaces. When you make interfaces fluent creates two wall boundaries? How u modeling them. i think this may be the problem gopal |
July 11, 2005, 16:14 |
Hi Gopal,
My model is a 90 degree slice of the complete domain. When I create the interfaces in FLUENT, it creates a second wall boundary for each interface. I used the wizard "Grid interfaces" for the interfaces and the command line "grid > modify-zones > make-periodic" for the periodic conditions. Thanks galeazzo |
July 11, 2005, 23:25 |
Dear Galeazzo
Here everything looks fine. I think the things should work with these conditions. May i know one more thing. How u seprate the inner and the outer region. R u using Tgrid or Tmerger for it? Gopal |
July 12, 2005, 16:15 |
Hi Gopal,
I make the inner and outer regions in Gambit at the same time, just use different continuun types. Thanks galeazzo |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 21:23 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 13:07 |
mesh missing after import in fluent | morteza08 | FLUENT | 0 | July 23, 2010 03:22 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 16:52 |
