high drag value
Old   April 5, 2005, 07:49
Default high drag value
sulfi
hi i am modelling only the under water portion of planing craft. we are using sinkage and trim values obtained from experiments. at low speed fluent is giving drag comparable with experiments. but at high speeds(5m/s) the drag values are 5 times the experimental.
what should i do to get the correct drag.
i have tried using all the turbulence models and differnt domain and also using different mesh sizes.
expecting your reply asap
thanking u in advance
sulfi
Old   April 8, 2005, 20:27
Default Re: high drag value
Sham
Hi Sulfi,
Can you tell me your domain and your mesh size. Are you sure that your reference values are correct?
Sham.
Getting too high Drag Coefficients nicolarre OpenFOAM Running, Solving & CFD 10 August 10, 2014 12:55
drag coeff to high - kOmegaSST turbulence model RugbyGandalf OpenFOAM 5 February 22, 2011 03:35
high amount of drag coefficient. about 15????Is it okay? ndabir CFX 3 February 1, 2010 18:10
High drag coeff. estimated by Gambit+fluent M. suuri FLUENT 6 November 6, 2006 09:02
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
