Monitors & UDF
Old   May 28, 2004, 05:53
Default Monitors & UDF
Sam
Hello, I would like to create monitors in a bowl of my cilinder represented in 3D. I would like to create monitors not in each cells of my domin but for example every XX cells. How can I do this?
Thanks for your help! Sam
Old   May 28, 2004, 11:43
Default Re: Monitors & UDF
kethireddy
Hi.. if u know geometrical location of ur monitor ( x,y,z)..create a point monitor and u can observe it.. i guess this is answer. Kethireddy..RWTH-Aachen,Germany
Old   May 29, 2004, 07:16
Sam
Thanks kethireddy.Yes, it's a solution but the problem is that i have too many points to place into my bowl. So i would like to get a command to put automatically them into the bowl.
Old   June 10, 2004, 22:08
shan
you can write a journal file to creat all those points in the bowl. regards, shan
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
