Incontinuity appears at the grid interface
Old   April 22, 2004, 00:00
Default Incontinuity appears at the grid interface
Ryan
I use two interface to define a grid interface. The computation result shows that an obvious incontinuity happens for the values at the two side of the grid interface.
what is the cause for this problem? and how to solve it?
Regards.
Old   April 22, 2004, 11:29
Default Re: Incontinuity appears at the grid interface
co2
i dont know for sure but may be wall and wall-shadow might help
Old   April 22, 2004, 11:32
Ryan
wall and wall shadow? I am sorry I am not very clear about your meanning. Could you explain it? Thanks.
Old   April 22, 2004, 12:23
co2
when you create the iterface use splitting tool in gambit --- that should give you a wall and wall shadow pair when you export your geometry in fluent.
for example split a volume using face and you will get a wall and wall shadow pair in fluent -- try it out and you will know
Old   April 23, 2004, 05:13
emre
If you have cells of very different sizes at the two sides of the interface, you should expect such discontinuites. Cell sizes may not be equal but cell volume ratios sould not be more than a few times.
Regards
emre
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
grid interface problems: ydzhang FLUENT 14 November 27, 2018 22:42
interface information from fem grid ztdep Main CFD Forum 0 January 14, 2011 22:13
Problem with BC on non-overlapping grid interface Ori Levin FLUENT 1 August 29, 2006 19:32
grid interface Dhandapani.s FLUENT 0 November 5, 2004 13:29
