April 16, 2004, 08:23 |
Curved Lines and Rakes
How do I create a curved line or rake for releasing particles / obtaining data for comparison, etc, etc.?
April 16, 2004, 18:23 |
Re: Curved Lines and Rakes
There is an option under "injections" where in you can specify a file which has co-ordinates from where the particles should be released.
-Ajay |
April 17, 2004, 07:35 |
Thanks, but I'd laso like to examine results along a curved line. Any thoughts on how I generate this?
April 17, 2004, 12:40 |
You could use the UDF's for DPM ( Discrete Phase model ) reffer the manual . Otherwise once you track a particle you can get the co-ordinates onto a file. Later you could write a UDF which access the file gets the co-ordinates and gives you the value of what ever you want at that location. -Ajay
3d anemometer velocity calculation | eddie toom | FLUENT | 0 | March 26, 2006 03:12 |
Lines and rakes | faiyahr | FLUENT | 1 | August 1, 2003 18:04 |
