rotating display of fluent
Old   September 25, 2003, 12:23
Default rotating display of fluent
Rose
Hey, In fluent, when I display the result, how could I rotate the XYZ freely. For example, I only hope it rotates on X-axis. Except for pressing only the left mouse, what eles should I do?
Thanks a lot
Old   September 26, 2003, 06:13
Default Re: rotating display of fluent
Erwin
If you press the Shift key simultaneously with the left mouse button the direction of rotation is limited to vertical or horizontal. I am not sure if that is what you need though.
Old   September 26, 2003, 06:36
emre
If you want the mouse buttons to work the same way it works in Gambit, you could change left to mouse-rotate, middle to mouse-dolly and right to mouse-roll-zoom from mouse buttons option under display pull-down menu. Thats the way i prefer, it has a disadvantage that you can not anchor at a point and pivot around it, but the greatest use of it is that you can enter into the model and go thru it by zooming in. Regards emre
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 12:55
Fluent simulation with rotating wheels of different materials enigma6666 FLUENT 0 August 14, 2011 20:03
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 14:43
How to display solid volume in fluent 6 Jack FLUENT 1 February 8, 2003 13:38
Fluent Graphics Display error John FLUENT 7 December 8, 2002 20:52
