Inlet B.C. of generating a homogenous flow?
Old   September 15, 2003, 09:00
Default Inlet B.C. of generating a homogenous flow?
David
Some references suggest the following inlet boundary conditions could generate homogenous flow in the simulation of atmosphere boundary layer in the absence of obstructions, and the simulated boundary layer will be self-sustaining. This means the inlet and outlet profiles of velocity and turbulence kinetic energy will keep the same. B.C.: U(z)=u*ln(z/z0)/k, K=u*^2/SQRT(Cu),Epsilon(z)=u*^3/k/z, k is the von Karman¡¯s constant.Cu=0.09.
I just use this B.C., but the outlet profile of TKE varies much comparing with the inlet one.The result is not self-sustaining. My case is 2D/3D incompressible, rectangular flow field, structured mesh, Segregated solver, Standard K-Epsilon model, standard wall function, roughness wall, SIMPLEC,QUICK, 10-4. Could anyone explain why? Thanks.
Species mass flow inlet lorenz FLUENT 3 March 15, 2012 08:26
Flow Reversal at the inlet salihovic CFX 3 July 15, 2010 11:50
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 19, 2003 15:03
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 17, 2003 20:23
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 03:19
