July 16, 2003, 11:43 |
Solid-liquid separation
I used the Euler model in the section of multiphase model to solve solid-liquid separating question, but I am not familar with the model and paramaters setting. So the results are not satisfied. Does someone else who have made similar caculation can give me some idea on how to deal with solid-liquid separating problem?
July 20, 2003, 18:29 |
Re: Solid-liquid separation
Try giving some more information about your case. Are you modeling sedimentation or what?
However, if the solid is a powder or it's granular, you should use the Granular option while defining phases. There is a tutorial about this model applied to an impeller. To obtain good results you have to choose the drag law with care. Read the manual for available laws. Hi ap |
[GAMBIT] help( solid and liquid mixing) | sanaz | ANSYS Meshing & Geometry | 6 | October 15, 2009 11:25 |
solid liquid phase change (melting/solidification) | ernane | CFX | 0 | February 3, 2009 15:24 |
Heat Transfer from Solid To Liquid! | Richard | FLUENT | 1 | January 20, 2006 06:43 |
Shacking CAN VOF HEAT LIQUID SOLID | Optixxx | FLUENT | 0 | July 30, 2005 12:42 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
