January 30, 2014, 04:28 |
#21 |
Anvesh
Rep Power: 12 |
Solution is converging at the end. For a channel with smooth surfaces either side, pressure drop is matching with theoretical drop. But if I use channel with lower surface has steps (such as 25 x 25 microns), we have to stop the simulation after fluid fills the channel (except the pockets), and get the pressure drop. But immediately after the start of flow, reversed flow occurring at outlet. Will it effect the result (in my case, its pressure drop)? If affects, how to avoid reverse flow?
P.S. I am new to FLUENT |
January 30, 2014, 04:51 |
#22 |
Ganapathy Iyer
Rep Power: 17 |
HI,
Suppose I have a duct. In the duct, the inlet occupies only 25% of the cross section a the top. The outlet occupies the complete cross section of the duct. In this case, if the duct length is small, the outlet will have reverse flow. This will also happen in the real world. If you want to avoid this, you must know the outlet pressure profile and apply it using a UDF or by dividing the outlet in appropriate number of parts. All this is tedious, so simply pull the outlet much further away from its current location, i.e. if the outlet is at say 100 micron from the inlet, (this may be your actual case), pull it till say 500 micron( this is not real, but this will avoid reverse flow) You can always measure dP across a plain representing the real outlet location |
February 17, 2014, 23:30 |
#23 |
Anvesh
Rep Power: 12 |
Thank you very much sir.
And one more problem I want to pose. Since I am imposing const. velocity condition at the pipe inlet I am getting a greater pressure drop, so I extended the upstream length. It is causing more computational time. So how to impose parabolic velocity inlet at the pipe inlet in FLUENT. Pl help me. |
July 17, 2014, 03:58 |
backflow
#24 |
Rep Power: 12 |
hi all,
ı have an rectangular geometry (lenght:76, width:27 mm). heat flux is applied from one of the vertical walls. ı have velocity inlet BC at lower part and also pressure outlet BC at upper part. velocity magnitute is zero (0) (no forced convection), initial gauge pressure is also zero and temperature is 298 K at velocity inlet BC. also, for pressure outlet BC gauge pressure is 0 and backflow temperature is set 298 K. initial temperature is also 298K. the problem is that reversed flow occured. "reversed flow in 34 faces on pressure-outlet 17" the solution is converged but ı am not sure it is right or not. any suggestion. thanks for you time. |
July 25, 2014, 16:17 |
reversed flow
#25 |
Rep Power: 12 |
hi all,
July 28, 2014, 08:47 |
#26 |
S
Rep Power: 12 |
i don't know if it helps, but if possible: try to use smaller time steps and with multiphase flows you should also enable specified operating density. it solved my problem with the reversed flow.
July 6, 2016, 04:23 |
Long pipe (laminar flow) gets reversed flow - not converging
#27 |
Omid Shekari
Rep Power: 10 |
My model is a u-shape pipe which is pretty long (220 cm total). There is heat flux from walls. The error is repeated continuously while solving. Also the answers are not converging.
Can anyone help me please? |
September 7, 2016, 17:06 |
#28 |
hussein
Rep Power: 10 |
hello
I have same problem but the result converge is the result will be right |
February 26, 2017, 01:23 |
#29 |
Rajendra Singh
Rep Power: 11 |
It happens due to a poor quality of mesh, abnormal boundary condition at inlet/outlet, short downstream length etc.
Remedies are: > if vortex formation/recirculation of flow near an outlet boundary, increase the downstream length. > check the mesh quality, improve it. > use higher order scheme > At last reduce the relaxation factor if necessary. |
September 15, 2017, 03:28 |
#30 |
shiva krishna
Rep Power: 9 |
Hello guys, (Doubt atmospheric conditions)
I am working on rectangular geometry with air as fluid. Actually i have one inlet at the one side face of the rectangle and one outlet is quite opposite to the other side face of the rectangle and reaming all are walls. I want atmospheric conditions at both inlet and outlet, for that i have taken pressure inlet and pressure outlet with default values (i.e. Gauge pressure is Zero). But unfortunately when I am simulating I am getting reverse flow. Moreover my solution is converging. Could you please any one explain me. What kind of mistake I have done. I am attaching my Residual and geometry images. |
February 1, 2019, 08:46 |
Revesed flow heat transfer
#31 |
alireza javadpour
Rep Power: 7 |
hi all, i have a square with heat generation rate inside that, i have three boundary conditions with constant temperature, but i dont have heat flux from one of walls, i want to simulate this problem in Fluent, could you please any one explain me??
November 16, 2020, 02:30 |
#32 | |
AJITH
Rep Power: 13 |
September 4, 2023, 14:28 |
#33 |
Rasel Kabir
Reverse flow is on, this massage will be shown when your result will diverging.
To solve this problem, you should check the boundary conditions properly and most importantly change the under relaxation factor from solver settings. Lower the relaxation factor, get higher stability in convergence. And I think thus you can get more better simulation result. |
September 6, 2023, 04:05 |
#34 | |
Moritz Kuhn
Rep Power: 17 |
Sorry, that is not correct. Reverse flow could be a normal flow behaviour at your boundary, if you not have a straight forward outflow. Especially at pressure outlets and buoyancy driven flows. There are some possiblitys which could help:
reversed flow | free | FLUENT | 4 | February 27, 2014 01:56 |
reversed flow during RNG in turbulence-k epsilon | Suman Kandula | FLUENT | 4 | April 2, 2012 07:12 |
Reversed flow...>>>Please HELP...! | sushii | FLUENT | 14 | October 29, 2007 04:27 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
reversed flow | Sastry | FLUENT | 5 | March 22, 2007 08:05 |
