gravity in fluent!
Old   December 25, 2002, 12:08
Default gravity in fluent!
winall
i want to simulate a upwrad flow of water in a circular pipe with gravity, the property of water is defined by UDF. when i set the property as constant it gets to convergence, but once i use my UDF, it divergenes. there is nothing wrong with my UDF! i try diffirent dicretion methods for pressure, eg. second orderĄ˘body force weighted and so on. Can anybody give me help!
Old   December 28, 2002, 02:36
Default Re: gravity in fluent!
zhhuang
use the pressure inlet and outlet B.C.
Old   January 6, 2003, 12:48
heydari
why u r using udf for your fluid prop.?
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 05:16
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 21:23
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 12:55
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 17:41
