November 6, 2002, 18:41 |
Species and reactions
if you select hydrogen-air as the mixture material, you will see that this mixture includes 9 volumetric species (H2, O2, H2O, O, H, OH, H2O2, HO2, N2), but only 1 global volumetric reaction (H2 + 1/2 O2 ---> H2O). How can it predict so many species with such a simple kinetics? How does Fluent calculate the source terms for all these species? Can anybody answer to these questions? Thanks a lot. |
November 9, 2002, 21:31 |
Re: Species and reactions
You can not predict the so many species with such a simple kinetics. Use PDF approach by using prePDF. prePDF is based on the 'fast chemistry'. I think that H2+O2 reaction can be regarded as 'fast chemistry'. Then you can predict many species, upto 20 for current Fluent version.
Sincerely, Jinwook |
November 11, 2002, 17:28 |
Thank you Jinwook for your answer. I know that with such a simple kinetics I cannot predict so many species, that's what makes me surprised.
If you enable Species Transport in Fluent 6, you can choose the hydrogen-air mixture, and see that in the mixture there are the 9 species I mentioned. If you enable Volumetric reaction, and you look in the materials panel, you will see that there is only one reaction (that is the global reaction of hydrogen oxidation). What I would like to know is: how can fluent calculate the concentrations of all the species in the mixture, if it apparently takes into account only one reaction, involving just H2, O2, and H2O? I hope that now my question is more clear... Regards, Ale |
activate species transport reactions | N K Ram | FLUENT | 2 | October 8, 2013 09:59 |
catalytic reactions - solid species? | Claud | FLUENT | 0 | February 5, 2008 03:41 |
Multiphase + Species reactions for wall surface ?? | Luke | FLUENT | 1 | June 25, 2006 10:07 |
Surface reactions in Species transport model | Karthick | FLUENT | 0 | May 26, 2004 06:24 |
Limitation of Number of Reactions and Species | Shahrokh Hajireza | Siemens | 0 | January 25, 2001 08:18 |
