May 9, 2001, 23:06 |
about combustion in fluent
When I use couple solver,finate rate model,massinlet boundary(subsonic)and pressure-outboundary(supersonic)to simulate all the flow in rocket moter(including nozzle), I get the result of cold flow,then I patch temperature to spark.I find the temperature is very high.After handrands of interation,there is error message: divergence detected-temporarily reducing courant number 0.5 and try again... divergence detected-temporarily reducing courant number 0.05 and try again... divergence detected-temporarily reducing courant number 0.005 and try again... divergence detected-temporarily reducing courant number 0.0005 and try again... divergence detected-temporarily reducing courant number 5e-5 and try again... error:internal error at line 688 in file"rp-mstage.c" divergence detected in AMG solver error object ) When I use segregated solver,finate rate model,massinlet boundary(subsonic)and outflow(subsonic)to simulate some part f the flow in rocket moter(not including nozzle,just the flow of chamber in rocket motor ),I get the result of cold flow,then I patch temperature to spark.And I also set under relaxtionressure:0.8,monument:0.25,and other scalars:0.5.After handrands of interation,there is message about reversed flow.After handrands of interation,there is error message: divergence detected-temporarily reducing courant number 0.5 and try again... divergence detected-temporarily reducing courant number 0.05 and try again... divergence detected-temporarily reducing courant number 0.005 and try again... divergence detected-temporarily reducing courant number 0.0005 and try again... divergence detected-temporarily reducing courant number 5e-5 and try again... error:internal error at line 719 in file"amgif.c" divergence detected in AMG solver error object ) If I just simulate the flow in chamber,I don't how to define the boundary at the end of chamber.I used the outflow boundary,but reversed flow come into being.If I define pessure-out boundary,I don't know how to define the value of pressure and temperature. Would you give me some advice?Any ansnwer will be welcome. Thank you. Mark 2001.5.10 |
May 10, 2001, 15:36 |
Re: about combustion in fluent
Try using the double precision version with a smaller courant number (e.g. <= 1.0 ) and see how it goes. Also make sure that your boundary conditions are correct, especially temerature. Initialize the data field with some reasonable values should also help.
December 31, 2016, 08:17 |
reducing corant number.
dd
I faced same problem in ansys 14.0 during analysis of rocket nozzle.The notification comes like temporary reducing corant number.do what should I do?
coal combustion in fluent | ramakant | FLUENT | 1 | April 29, 2014 10:40 |
Limitation of Fluent (Combustion Modeling) | Arun | FLUENT | 5 | September 20, 2012 07:09 |
Combustion SImulation in Fluent | santhosh1987 | FLUENT | 1 | May 14, 2010 17:03 |
combustion in fluent..help | ssj | FLUENT | 1 | June 11, 2007 13:54 |
Fluent error in periodic PDF combustion cases?? | George | FLUENT | 2 | March 8, 2004 17:45 |
