Contours of density gradient in fluent 5?
Old   March 24, 2000, 11:18
Default Contours of density gradient in fluent 5?
Ricky Wong
I'm modeling air jets of various exit geometries which I've previously taken experimental measurements from. As well as comparing quantitative measurements with the CFD I'd like to compare the Schlieren images I took of the test jets with the CFD. Is there a easy way of making Fluent 5.2.3 display the jet as a Schlieren image (changes in density gradient) for direct comparison with my experimental images. Do I need to use User Defined Functions?
thanks for any help
Ricky
p.s. I think the UDF database idea would be a great idea. Although I don't really have anything to contribute to it, it would be al least a starting point for those like myself just starting to think about using them.
Old   April 19, 2014, 09:32
Vishnu C
vishnu_240 is on a distinguished road
Ho no even after 14 years there is no answer to it, and how will i find it?
vishnu_240 is offline   Reply With Quote
Old   April 21, 2014, 11:04
shoeb khan
shk12345 is on a distinguished road
Originally Posted by Ricky Wong
;94026
thanks for any help
Ricky
I am not sure about the problem what you are saying. But i think that you can take the pressure plots from the fluent and then compare them with your experimental images. Since pressure is directly proportional to density you can compare the results.
Hope that helps
shk
shk12345 is offline   Reply With Quote
Old   May 19, 2015, 02:39
Vishnu C
Yah true, but Fluent itself gives Gradient Density contour.
Can I use tabulated density data in FLUENT? Ellen FLUENT 7 June 24, 2023 06:31
How to plot FLUENT contours on MATLAB Thiago Combustion FLUENT 1 October 10, 2013 15:13
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
Inputting pressure gradient in Fluent Josyula FLUENT 2 December 23, 2009 08:26
FLUENT - velocity gradient Sue Main CFD Forum 1 May 8, 2006 16:09
