Melting Dependent UDF
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   July 6, 2023, 10:02
Default Melting Dependent UDF
Melody
dwnzng is on a distinguished road
I am simulating SLM of basalt on ansys fluent and I want to write a UDF which says that the density before melting 1810, the density during the liquid state is 2760, and the density after resolidification is 2704. Originally I had created a variable "melted" to track whether the sample has already been melted, and thus the density would depend on both temperature and the melted variable. However, because the function is called from scratch every iteration, the melted variable is not stored anywhere and my function doesn't work. I also don't think it's possible to code it based on time because not all elements melt at the same time. I've attached a screenshot of my code so far, is there any other way to make my vision work? Screenshot 2023-07-06 145940.png
dwnzng is offline   Reply With Quote
Old   July 6, 2023, 16:34
CFDKareem's Avatar
Kareem
CFDKareem is on a distinguished road
Is there a reason you are trying to do this with a UDF rather than a piecewise equation in the materials GUI?
Please like the answer if it helped!
Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured
CFDKareem is offline   Reply With Quote
Old   July 7, 2023, 03:58
Melody
Thanks for the reply, I am using a UDF because the initial density of 1810 has a temperature range of 300K - 1450K, but the resolidified density at the end of 2704 has the same temperature range, so I didn't think that was possible to do using the materials GUI
Old   July 11, 2023, 05:21
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may use user defined memory to store flag
C_UDMI(c,t,0) = value
change melting variable to C_UDMI(c,t,0).
allocate user defined memory location = 1 at fluent GUI
next time put the code here, so It could be modified
on the other hand, you may use piecewise equation for this simulations, as was suggested
dwnzng likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
density, melting/solidification, slm, udf, udf code
UDF for Temperature Dependent Energy Source er.mkumar Fluent UDF and Scheme Programming 9 March 14, 2024 05:01
Pressure&Temperature dependent viscosity UDF - error in calculation JINXING FLUENT 5 January 12, 2023 05:24
Creating a heat Flux UDF with a temperature Dependent argument nagas Fluent UDF and Scheme Programming 3 March 20, 2018 08:14
udf for moving heat flux for the simulation of laser melting rishitosh Fluent UDF and Scheme Programming 2 January 24, 2018 02:01
Problems in converging viscosity UDF dependent upon strain rate and temperature. alexskerhut Fluent UDF and Scheme Programming 1 March 17, 2016 08:19
