Pressure&Temperature dependent viscosity UDF - error in calculation
Like Tree2Likes
  • 1 Post By andrew-c
  • 1 Post By JINXING
Old   January 11, 2023, 02:23
Default Pressure&Temperature dependent viscosity UDF - error in calculation
JINXING is on a distinguished road
I am trying to write a UDF for Fluent to define the working fluid viscosity through the pressure and temperature inside control valve.
Using pressure inlet(40bar) and pressure outlet(0) steady simulation method. Before applying UDF, I used constant viscosity to check the model and determined the pressure range inside the simulation domain(-1.4bar, 40bar).
The UDF can be successfully compiled and loaded. After starting calculation, I got error messages.
I tried to set temperature as constant or pressure as constant to check the reliability of UDF. The simulation worked well when the UDF pressure condition was set as constant(real P = 40.). But the same error appeared when the UDF temperature condition was set as constant(real T = 72.).
I also tried to use constant viscosity to get a converged result and then apply UDF, but the same error appeared.
Here is my UDF and error messages:
Any help is greatly appreciated.
Thank you!
JINXING is offline   Reply With Quote
Old   January 11, 2023, 04:11
Realizable k-e turbulence model, SIMPLEC method
Old   January 11, 2023, 10:18
Andrew
andrew-c is on a distinguished road
Have you validated the values of viscosity that are coming out of your UDF to ensure they are reasonable? You can add a line in your UDF to print the mu when the UDF runs.
It may also be the distinction between gauge and absolute pressure. I'm pretty sure C_P gives you gauge pressure values, whereas i'm guessing your equation for viscosity is based on absolute pressures. You can add your operating pressure to C_P to make it the absolute pressure, this may fix it.
I think there's a command for obtaining the operating pressure during the run too; something like "get_real("operating-pressure") or something similar. You can also just use the value of your operating pressure if you don't plan on changing it frequently.
JINXING likes this.
andrew-c is offline   Reply With Quote
Old   January 11, 2023, 12:30
Lorenzo Galieti
LoGaL is on a distinguished road
Most probably you are using gauge pressures and not absolute ones like andrew-c is saying.
For which fluid do you need to implement this model ?
LoGaL is offline   Reply With Quote
Old   January 12, 2023, 05:16
Thank you andrew-c for your reply.
Printing the mu valve is a good method to monitor the equation's reliability.
I solved the error by changing the unit to SI format. I found the UDF can only use the SI unit even though I changed the unit format(pa->bar, K->℃) in Fluent.
Thank you very much for your suggestion.
andrew-c likes this.
Old   January 12, 2023, 05:24
Thank you LoGaL for your reply.
I solved the error by changing the unit to SI format used in the equation.
I am studying the fuel(IFO380) flow characteristics inside the control valve of different opening degrees.
Temperature and Strain Rate Dependent Viscosity UDF Code SANDIPSINH JODDHA Fluent UDF and Scheme Programming 2 April 5, 2022 12:48
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Time dependent angular velocity calculation UDF shashankmechguy Fluent UDF and Scheme Programming 1 July 26, 2018 03:23
Help with unsteady calculation with source/sink UDF RobV Fluent UDF and Scheme Programming 3 March 10, 2016 04:45
Temperature dependent Non-Newtonian viscosity UDF cric92 Fluent UDF and Scheme Programming 0 April 14, 2013 07:31
