October 31, 2021, 08:41 |
MSMD Model Issues [SOLVED]
Rep Power: 7 |
Hi all,
I am trying to simulate a basic 6s2p battery pack's air cooling problem. However, when I try to carry out the analysis, I encounter:
Last edited by SplendidaVitia; November 3, 2021 at 01:45. Reason: Problem is solved. |
October 31, 2021, 08:48 |
Rep Power: 7 |
I am writing this reply to post some more images and give some additional information. When I define the busbar materials through user-defined diffusivity, iterations don't even start, it gives Divergence in amg-solver: uds-0 error. If I switch it to defined-per-uds, it sometimes works. I don't know what to do. Thank you in advance.
October 31, 2021, 18:56 |
Alexander
Rep Power: 34 |
basbar material is defined same way as tabs
when you have a message that some zone is not connected this is a critical error and must be fixed in your second message I can see, that all zones were defined correctly. use small timestep to check where heat comes from. if you are using default parameters of ntgk or ecm, there should be no problems in battery performance simulation on small C-rates
best regards ****************************** press LIKE if this message was helpful |
November 1, 2021, 00:28 |
#4 | |
Rep Power: 7 |
I both tried it with the default parameters and somewhat modified parameters (Like changing system voltage to my calculation, DoD etc.). I assign the same material to both tabs and busbars (user-defined). As you said, this critical error may be causing the segmentation fault in ECM, I guess. I tried to go step-by-step with the advanced add-on module tutorials. But as I said, I cannot wrap my head around what might be the cause of this. I tried to define the contacts with automatic connections and also with forming a new part and imprinting the faces. One of the other things that I tried was instead of importing a stp file, drawing the model in Design Modeler. It didn't help either. I am going to fidget with it a bit. Meanwhile, I am open to any other suggestions as well. |
November 2, 2021, 21:32 |
Alexander
Rep Power: 34 |
most likely the problem comes from your mesh (quality is not good enough) or boundary conditions.
as you are using contacts make sure you defined coupled boundary condition there. you may try to make the whole model without contacts (conformal mesh everywhere), this is how you may check if the problem comes from contacts
November 3, 2021, 01:43 |
#6 | |
Rep Power: 7 |
December 29, 2022, 13:32 |
I'm facing the issue of divergence detected with ntgk model with thermal runaway
Abhilash
I am using a 6x6 battery pack for simulation while connecting those through busbars divergence is detected at uds 0 i tried with multiple settings but issue is not solved .. please help me with this
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Convergence issues with my k-w model | pablosanchez03 | FLUENT | 2 | July 30, 2016 13:35 |
Turbulence Model - Linking Issues? | AA29 | OpenFOAM Programming & Development | 3 | June 20, 2014 15:21 |
Issues with an attempt to model an inline tube bank | A Muharib | STAR-CCM+ | 4 | October 22, 2011 23:54 |
