How to model a reversible reaction with a solid catalyst in ANSYS Fluent? |
April 11, 2021, 10:33 |
Have a nice time!
Rep Power: 11 |
Hello, I have a reversible reaction and a solid catalyst is used. In Fluent I see volumetric reaction and I can select backward reaction to define the reversible behavior. However, I am not able to define the catalyst unless I make it particle surface reaction not volumetric.
How can I define the catalyst + the backward reaction? Thank you! |
April 12, 2021, 05:09 |
Jeroen
Rep Power: 5 |
If you intend to use the particle surface model you need to define your solid particles via the discrete phase model.
GPU acceleration in Ansys Fluent | flotus1 | Hardware | 63 | May 12, 2023 03:48 |
ANSYS Fluent rotation of SOLID drum filled with water | coms0 | FLUENT | 0 | October 26, 2019 10:49 |
Hydrodynamic analysis of submarine model with ANSYS FLUENT? | Sovereignty | ANSYS | 0 | January 20, 2019 19:36 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
