August 28, 2020, 08:00 |
Residuals not converging
Aniket Dalvi
Rep Power: 6 |
I am simulating Rayleigh Benard Convection between two horizontal plates for steady and laminar case. I am attaching a screenshot of my residuals along with convergence criteria. Any suggestions for reaching convergence will be highly appreciated.
Screenshot (1329).jpg |
September 2, 2020, 02:01 |
JSM
Rep Power: 20 |
There are two possible reasons. 1. If your initial solution is very close to final converged solution, then residual monitors will not go down. 2. If flow is in transient nature, then it may not converge much. In both scenario, it is better to put some monitor points at critical regions and monitor pressure or velocity. If it is flat, then solution can be considered as converged. If oscillation is too high at monitor points, then change to transient solver.
With regards, JSM |
September 4, 2020, 06:03 |
#3 | |
Aniket Dalvi
Rep Power: 6 |
I tried using unsteady and turbulent k-epsilon model. In this case, I ran the simulation for a flow time of 20 mins but failed to see any flow occur. I am attaching the temp and velocity contours. velocity.png contour-1.png |
September 6, 2020, 20:51 |
JSM
Rep Power: 20 |
For simulations like Rayleigh–Benard convection, at least transient simulation should converge. Then it looks, meshing & solver set up might be the reason for this convergence issue. There are many questions you have to answer and think...
I recommend to read some journal papers about Rayleigh-Benard convection to understand the phenomenon and underlying physics of this simulation. Also read Ansys documentation about natural convection simulations. This might help you to get the converged solution quickly.
With regards, JSM |
convergence issues, fluent - parallel, natural convection |
Residuals in inviscid solution not converging | ari003 | FLUENT | 1 | June 25, 2019 05:22 |
Pimplefoam - residuals not converging | cyln | OpenFOAM Running, Solving & CFD | 16 | November 7, 2017 13:46 |
strange residuals - converging -then diverging- then oscillating - then getting weird | juste | FLUENT | 3 | December 3, 2016 18:26 |
k and epsilon residuals not converging | NISHIKANT TAMRAKAR | FLUENT | 9 | October 11, 2011 11:47 |
Converging the Turbulent Equation Residuals | Josh | CFX | 0 | November 29, 2010 20:02 |
