effect extension inlet and outlet on Ground Heat Exchanger corrugated tube
Like Tree2Likes
  • 1 Post By vinerm
  • 1 Post By vinerm
Old   March 27, 2020, 19:23
Default effect extension inlet and outlet on Ground Heat Exchanger corrugated tube
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Dear all,
I want to simulate Ground Heat Exchanger with corrugated tube in AnsysFluent 17.2. Due to temperature fluctuation in the ground, heat applied in the ground is transient. I find the inlet and outlet is too close to the corrugated tube. I am afraid the back flow could affect the simulation result. Hence, I lengthen the inlet section and outlet section (10 * Internal diameter of tube) to make sure that thermal and hydrodynamics flow is fully developed. but I put wall of the extension into Adiabatic condition. Because I want to see the effect heat transfer only in corrugated side. Is my extension methods correct?
Thank you
Best regards
Now Or Never!!!
teguhtf is offline   Reply With Quote
Old   March 28, 2020, 16:38
Default Adiabatic
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
It would not make much difference. If temperature field is a passive scalar, i.e., it does not affect the properties of the fluid, then it would not have any effect at all, except its own uniformity within the fluid, which you cannot control until you set diffusion coefficient to 0 in the extended region. In other words, heat transfer will be as per the boundaries where thermal interaction takes place, however, thermal field will keep on developing even in the extended outlet.
teguhtf likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 30, 2020, 20:59
teguhtf's Avatar
teguh hady
Dear vinerm
Thank you for your reply. The working fluid is water and temperature fluctuation is negligible hence water properties is constant.
In above sentence, the flow will be still developing in extension region. I'm curious whether the temperature will change in the extension region because the flow will still be developing.
Thank you for your help
Teguh
Now Or Never!!!
Old   March 31, 2020, 04:58
Default Temperature Change
vinerm's Avatar
Vinerm
Since the walls are adiabatic in the extended region, the thermal energy will be conserved. However, the distribution of the temperature will keep on resolving. Adiabatic walls will cause an effect on the thermal field near the boundaries, so, for the rest of the length, thermal field will try to adjust to this new condition and will also try to become as uniform as possible due to diffusion.
teguhtf likes this.
Regards,
Vinerm
Old   April 9, 2020, 01:35
teguhtf's Avatar
teguh hady
Dear vinerm
I am sorry for late reply. Thank you for explaining the phenomenon. It helps me a lot.
Thank you
Best regards
teguh
Now Or Never!!!
corrugated pipe, fully developed condition, ground heat exchanger, transient
natural convection in square cavity having inlet and outlet sujeet OpenFOAM Running, Solving & CFD 1 November 2, 2019 03:17
CFD Fluent tutorial - Shell and tube heat exchanger - PROBLEM tom96 FLUENT 1 May 21, 2018 01:24
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
