Residuals in inviscid solution not converging
Old   June 24, 2019, 06:49
Default Residuals in inviscid solution not converging
Arijit Saha
ari003 is on a distinguished road
Problem statement- There are two airfoil separated by some specified amount of distance and I am supposed to take the reading of Cl of both of the airfoil at different angle of attack while the interaction of one airfoil over the other persists.
I started with inviscid model but the result is very dissatisfying. The residuals are not converging, Cl monitor is oscillating heavily but the mass flux is under control. I tried the successive attempt by reducing the Pressure and momentum relaxation factor but the problem still continued. In the console window the statement is appearing " Stabilizing pressure coupled to enhance linear solver robustness.", don't know what does it mean. Any kind of help will be really appreciated.
ari003 is offline   Reply With Quote
Old   June 25, 2019, 05:22
ngoctm is on a distinguished road
Hi Arijit,
Your problem may be the same here:
Divergence detected in AMG solver: temperature
ngoctm is offline   Reply With Quote
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli mmkkeshavarzi FLUENT 1 June 28, 2024 08:03
Converging the solution aja1345 FLUENT 13 June 15, 2022 00:46
My steady state solution converges for a while but stops converging C.C Fluent UDF and Scheme Programming 0 October 9, 2013 12:11
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 08:51
Fluent Solution Residuals RC FLUENT 2 September 30, 2003 03:34
